454 fitment question
Old Jan 30, 2007 | 01:31 AM
83camaro's Avatar
Default 454 fitment question
I know ive been asking alot of questions but i can't really find any info on this. Is there anyway I can fit a 454 in an 83 Camaro? I mean, the engine bay is about the same size as a Monte Carlo, and will fit in it. If so, does anybody know where i can find some motor mounts for this? Thanks for your help guys.
Old Jan 30, 2007 | 01:52 AM
MadMikeZ28's Avatar
Default RE: 454 fitment question
It can fit. I got some books with a pic or two with BBs in a third gen. I think you just use the big block cups on the motor. They are shorter than a small block for the extra width of the Big block.
Old Jan 30, 2007 | 02:37 AM
Raven91Z28's Avatar
Yea, I've seen a third gen with a 454 in it...it fits...
Old Jan 30, 2007 | 02:43 AM
83camaro's Avatar
can somebody tell me a place that would prob carry the mounts? Ive been looking around but i can only find the mounts for the 350.
Old Jan 30, 2007 | 02:58 AM
Raven91Z28's Avatar
I would just get a set of 454 mounts at a junk yard first and fit them up. They might work with some slight modification. If nothing else, it's a starting point for cheap. My friend and I ended up making our own motor mounts for his 406 LT1 engine and it wasn't too bad...
Old Jan 30, 2007 | 03:15 AM
MadMikeZ28's Avatar
Use the 350 mounts on the frame and the 454 mounts on the block.
Old Jan 30, 2007 | 03:30 PM
350rs's Avatar
March 2008 ROTM
what about failure? are those 350 frame mounts strong enough? i wouldnt know, but ive been entertaining a lot of things for my car, and a 454 is one of them. So i would like to know.
Old Jan 30, 2007 | 09:14 PM
Raven91Z28's Avatar
Yea, they're strong enough, you could even use stock 305 mounts....Check this out....
http://camarotech.com/Gen3-BigBlockSwap.html
Old Jan 30, 2007 | 10:04 PM
MadMikeZ28's Avatar
You could use the urethane mounts if you are worried about strength. They would just make for a lot more noise ffrom the vibration traveling through the chassis.
GetReady
Aug 28, 2014 12:11 AM
74camaro.
Mar 5, 2013 06:10 PM
streetsteve
13
Jun 5, 2012 06:44 AM
newman3928
Mar 14, 2011 09:28 AM
fuzzyz28
Feb 5, 2008 12:22 PM
