396 in my Camaro?
Old Dec 19, 2007 | 03:42 PM
NaturallyAspirated's Avatar
Default 396 in my Camaro?
I've heard of a lot of people putting big blocks in their 3rd Gen Camaros. But what about the Transmission. Will it handle the power? And how much of a project is it? Somebody offered me a complete 396 motor out of a Chevelle to put in my Camaro for cheap. Thought I would atleast look into it.
Old Dec 19, 2007 | 04:13 PM
1990CamaroRS's Avatar
Fancy Sparkle
Default RE: 396 in my Camaro?
if you get a 4 speed manual trans with it, go for it. if it doesn't have one, i'd recommend a TH350 or TH400 auto, they should be able to take the power
Old Dec 22, 2007 | 12:24 AM
buckfever's Avatar
it would be a difficult project.. not a whole lotta room under the hood with a SB just imagine a BB.. you would need a TKO or an old 4 sp or a trbo 350 or 400 alotta options you could go with on trannys.
Old Dec 22, 2007 | 09:46 AM
Iowa87CamaroRS's Avatar
I think shnormo told me that the HP to weight ratio also wouldn't make it worh it....he's a very wise man...but if it's very cheap...like i got my 400 SB for ($200 for the whole car) then I would say go for it
Old Jan 7, 2008 | 11:06 AM
6426yy's Avatar
Just the price of headers was enough to deter me. Unless someone knows where to get a cheap set all the ones I've found are like $500 and up. Then you'd probably still have to dimple them.
Old Jan 7, 2008 | 01:27 PM
350rs's Avatar
March 2008 ROTM
im suprised they werent more than that. i bought a set of hooker headers for my 350 and they ran me about 500 with the y-pipe.
Old Jan 8, 2008 | 02:53 PM
Jr. Mechanic's Avatar
August 2009 ROTM
ORIGINAL: Iowa87CamaroRS
That is absolutely correct, the HP to weight ratio is NOT worth the extra money and trouble. I had the option of building a 402 BB or my 350. After much thought, I decided on the 350. Parts are more plentiful, cheaper, and it is easy to get HP out of.
Old Jan 11, 2008 | 06:34 PM
camaro1984's Avatar
also the weight of the engine drags the car down so any more power you do make the weight just brings it back to the same as a small block so why not stay with the small block if built right they make as much if not more hp than a b/b and alot cheaper
