325Hp 305
Old Jun 3, 2007 | 11:53 PM
Celticsfan's Avatar
Default 325Hp 305
I know there is another thread about this but i didnt want to hijack it...
well anyway here is the site: http://www.goingfaster.com/spo/325_h...chevrolet.html
Their motor is carb'd where mine will be fuel injected...have the 85 LB9 v8, 215hp@4400 rpm, 275lb torque @3200...
Well in the build they use a new manifold and carb, since I am FI would a new intake do me any good? And would the Cam and The Vortec heads still work with my set up? I know the 350 is more economical ive had this debate before but i want to stay with the 305...Lets say i got the cam and heads in the article, new intake, and headers, what kind of numbers am i looking at? I already have dual cat back w/ flowmaster 40's
Thanks!
Old Jun 4, 2007 | 07:18 AM
350rs's Avatar
March 2008 ROTM
Default RE: 325Hp 305
the vortec heads NEED a vortec style intake manifold, they bolt up differently, and i THINK the angle is slightly different, but i dont know for sure. But if you can find a FI intake thats vortec, it would work perfectly.
Old Jun 4, 2007 | 07:39 AM
Celticsfan's Avatar
I just found this:
http://store.summitracing.com/partde...700+4294822100
So lets say i get the cam, vortec heads, that intake and mayb headers what am i looking at?
Old Jun 4, 2007 | 10:24 AM
92camaroRS's Avatar
u gotta get the headers and y pipe first before anything. And with headers and y pipe, cam, heads, intake your lookin at around a 75-80 hp increase.
Old Jun 4, 2007 | 10:52 AM
ORIGINAL: Celticsfan
I just found this:
That manifold will work fine if you going to use TPI. You may want to see if bigger runners are available for the manifold, and also a larger plenum. The Vortec heads and cam will work OK, but as mentioned in the article, the power band will move up so you should get some fatter rear end gears. The headers and exhaust will definitely help. Also, there is going to be a lot FI and spark timing tuning required. This should be left to a dyno tuning facility. Look to spend $ 500 + for that service.
Old Jun 4, 2007 | 01:07 PM
Celticsfan's Avatar
Damn...that just shot that idea down...I really want some more power for this summer, but the 350 swap will take too long and then the parts AND tuning, wont be making enough...dont really want nitrous dont know if the motor will handle it...
EDIT: for the hell of it what kinda gears would i need? Right now i have 3.23s posi
Old Jun 4, 2007 | 03:50 PM
350rs's Avatar
March 2008 ROTM
i personally wouldnt go ANY lower than 3.73. Any lower and your just makin more "torque" we will call it... just spins and dosent wanna go. To light of a car, not big enough rear tires.
Old Jun 5, 2007 | 08:29 PM
Celticsfan's Avatar
Would nitrious be a viable option? I was thinking turbo but there alot of fabrication involved...
Old Jun 6, 2007 | 06:14 PM
350rs's Avatar
March 2008 ROTM
skip the NOS on a stock motor.
Old Jun 6, 2007 | 08:26 PM
Celticsfan's Avatar
Ya i figured that, well i just found out im getting a 10/hr 40-50 hour job this summer, im pretty pumped should have extra cash for the car now.
