305 cam in a 350
305 cam in a 350
so im pullin the old tired 305 out and in it's place is a 350.. now with this 350 it's nothin special. the block was pulled out of a 93 chevy 2500. i'm changin all the gasket an i had the heads milled .20 now im reuseing the intake manifold ( there is one on the 350) also i know that because this was a trck engine chevy put a cam profile setup for low end instead of top.. and im pretty sure that the 305 is setup for more top end.. i was wonderin witch cam ya'll think would be more suitiable for my setup?
RE: 305 cam in a 350
A new OEM type cam & lifter kit can be bought for well under $ 100 in most cases, so get the right cam for Your engine 'cause You shouldn't use a used cam and lifters in a fresh engine. If You didn't keep the lifters in order for Their cam lobes then they're throw aways anyhow.
huh? i took out the push rods an the lifter but i left the valve/vlave springs an retainers in. so... the block i left alone.. the heads were milled but the block still i used. i changing all the gaskets. i left the oem cam (truck) in the block.
Then that would be good to use. Probably should put a new set of lifters in though, wouldn't hurt. Those cams make alot of low end torque and don't do too bad up high either.
