305-350 swap
I was wanting to go with a 330 h.p. G.M. crate motor in my 92 RS which has a TBI 305. What do I need to do in terms of intake, throttle body, and ECM? Also can I keep it street legal with all EGR components? Anyone who can help me with this matter I would be deeply appriciative. I have done alot of work on this thing to make it gleam now I want it to streak. Please help and I will be forever indebted to this forum. Thanks to all who post and salute to the camaro inthusiasts, I would never want to do this much work to any other car.
thanks
thanks
You could run it with all your stuff but the right way would be to:
Replace the knock sensor and ESC with those for a 350, Computer chip and fuel injectors, all for a 350.
You can also keep everything to kepp it smog legal. Just Keep the fact its a 350 a secret. In California they make you go through the trouble of an engine change. Its not really trouble but its more work afterwards and its not worth it to say anything.
Hey thanks for the reply. That sounds good, now I'm one step closer. Should I find an intake and TBI out of a Silverado or just change the injectors. I'm going for the maximum output. And by the way how do I post pictures on here?
If your TBI is good just get injectors. Or the whole deal if its cheaper.
As for posting pics. I am the wrong person to ask. [8D]
I you click "post reply" there will be an area right at the bottom of the message window in the grey area. One will say click to upload image and the other will say embed (that will put a small image in the message to click on and open in another window)
Or I have just started useing photobucket.com and after uploading chose the image and make it into an http/url then copy that and click the yellow square abouve the message window on the right side that says "add image" and past the http link. It will post the pic in the message.
I am kinda new at doing this so its greek to me
Hey I hope you all got your magnifying glasses. I got it to work but I had to make it alot smaller than it was in order to fit. If there's an easy way to show a larger picture please let me know.
Thanks
Thanks
the silverado ports are larger than the camaros TBI ports, is what i have heard. Creat more low end torque, dont ask me how or why, or if its even true, its just what i have been told. Im running one on mine and i can tell you this, i have loads of low end torque.
9434V6
09-08-2011 11:51 AM
