2.8 to 3.4 ?
2.8 to 3.4 ?
I have a 1989 RS, 2.8 5spd, I would like to put a new crate engine in herand make as close to astraight swap as possible.Their is a 3.4 availible, but I'm not sure if everthing will bolt up.
Andwhat componants might have to be changed or upgraded.
RE: 2.8 to 3.4 ?
EVERYTHING!! It will not bolt up for ****, if you want to swap, then go for a 350, flat out easiest swap you can do.
Decide whether you want to go carb, TBI, or TPI, carb will make everything 10x easier.
Remove your engine and trans, get a 350, transmission, pullys and accesssories, and either a regulator on the stock pump, or remove the pump and put a mechanical pump on the block. Remove all the computer BS, get 350 mounts, and you are done.
RE: 2.8 to 3.4 ?
It looks as though Jr Mechanic will not verify why nothing will bolt up in the 2.8-3.4 swap.
The HT 3.4 was first in the GM Performance Parts catalog as an upgrade replacement for tired 2.8 S10s'. It was rated at 160 hp for 82-85 carbed trucks. If it bolts into an S10 it will bolt into your Camaro and should be a straight forward replacemement. Just check and make sure the oil pan looks the same.
