1990 RS will not satart. please help me
okay yesterday MY 90 camaro started up perfect. this morning put key in ignition turned th key Nothing. i have dash lights and lights,power windows work.i can hear the fuel pump working. but nothing when i turn the key.
god this car is driving me crazy.and on my day off from work this happends to me
any ideas? what can i check or do....i charged the battery it has a full charge.
Check the cables for tightness at the battery.
You should not be able to turn them. If you can they're too loose.
The starter takes the most current from your battery. All lights may work but starter might not turn if there's a relatively loose connection. If battery connections are tight starter might be bad.
