1989 Rs heater Problems
Old Jan 3, 2009 | 10:32 AM
SimplexDesign's Avatar
Default 1989 Rs heater Problems
For some reason even thoughthe blower is working on the carno heat actually comes from the vents. I would like to help get the problem fixed asap esp sincemy friend who owns the car isin NJso heatright now would be nice. I know that the radiator fanis hardwired to alwaysbe on when then car is running could that be causing no heat? or should it still be getting heat with its hardwired? Thanks for any info in advance
Old Jan 3, 2009 | 11:24 AM
350rs's Avatar
March 2008 ROTM
Default RE: 1989 Rs heater Problems
are you talking about the fans being hardwired? its impossible to hardwire a radiator.. lol
check the two hoses that go back to the core. make sure they are both hot. if only one is hot, there is a clog in the core. if none are hot then the valve isnt opening allowing water to flow back there. Do you know if a stop leak was added to the system at all?
Old Jan 3, 2009 | 12:09 PM
1) If the thermostat is bad and stuck open, it will take forever for the engine to heat up, and even longer for you to get inside heat.
2) The radiator fan should not be hot-wired to run all the time, at least not in the winter time. The fan is cooling off an already cold engine and radiator, making matters worse.
Old Jan 3, 2009 | 03:48 PM
irocktheIROC's Avatar
maro69 is right, thats what was wrong with my heater, there wasnt even a thermo in it, so the engine wouldnt get past like 70deg.....it sucked...
Old Jan 3, 2009 | 07:20 PM
ORIGINAL: 350rs
hahah yea typo meant the fan... Both the hoses are cold and when I disconnected the one it was dry
Old Jan 3, 2009 | 07:23 PM
ORIGINAL: Camaro 69
The Thermostat is good brand new so I dont think it has to do with the problem.. And I know the radiator fan shouldnt be hardwired but it was that way when the car was purchased
Oh and I have to say badass ride.. I Love 69 camaros they are probably my favorite car of all time and yours is very nice
Old Jan 3, 2009 | 08:35 PM
ORIGINAL: SimplexDesign
I think you're way low on coolant. Is the radiator full? It doesn't matter which hose you disconnect, it shouldn't be dry. Which one did you disconnect?
Old Jan 3, 2009 | 09:17 PM
350rs's Avatar
March 2008 ROTM
if however your coolant levels are good. sound like that valve is siezed shut. but even if it were siezed it should have SOMETHING in it..
Old Jan 4, 2009 | 10:12 AM
ORIGINAL: Camaro 69
Radiator is full and there was a drop and I meana littledrop in the top line going in
ORIGINAL: 350rs
This sounds like it could be the problem
