06 Vette Wheel Fitment?
i have a 84 base model camaro with the carb 305. i went out on a limb and picked up some corvette c6 wheels for 400 bucks. they look brand new and are gm stamped so they are factory. the front rims are 18x8.5's and rear are 19x10's. i went to the shop to see how bad they wouldnt fit, and the front would prolly be alright with minor wheel well cutting and spacers. the rear rims are gonna be tricky. i couldn't even get the holes close to the studs. the backspacing is like 8 5/16's. i'm thinkin maybe a forth gen rear end with spacers might help out with that. i'm not mechanically inclined but that's what i think. what would you guys suggest?
the 4th gen rear is the same size as the 3rd gen, there are only a few minor internal difference. you are going to have to find a custom wheel spacer/adapter. i think though anything more than a 9 inch wide wheel will either need it to stick way out of the fender, or cut out the inner fender and make tubs. im not 100% on that though because i have seen magazines with c5 wheels on a 3rd gen, but it was never covered on the build up what is required to do. i say best of luck and let us know how it goes
You're still going to need to use spacer adapters. 4th gen Camaro wheels won't even fit onto a 3rd gen without using 1.5"~2" thick adapters, I've tried.
They sell special adapters for the 3rd gen to accept 4 gen rims different offset but same bolt pattern you need 2 inch spacer adapter i believe i picked up a set off ebay a few years ago and paid 110 for all four but i know that there are companys that specialize in this just look on ebay or search yahoo for a compnay
yea.. ive got a 4th gen rear to go into mine.. its wider so.. about 2 inches on both sides.
pics....for evidence. i dont think they are any different in size, i thought the only changes were to 28 spline axles and abs.
