03m45 infintia... 92 camaro rs question.....
i have a 03 infinti m45 that i totaled out in a crash, but the engine still is in tack. i also have a 92 chevy camaro rs that runs great. How conceivable would it be to switch out my 03 infinti m45 engine with my chevey camaro engine?
it would take ALOT of work time and money also alot of custom fab work if you have the skills time and money id say do it up altho id rather not see an infinti engine in a chevy but thats my opinion
That depends on you. Can you make steel parts? Weld? Machine shop? For a fabricator this would be fairly easy swap but most guys Cant make their own motor mounts to make up their own wiring harness it could cost you thousands in custom work. You really need to be good at EFI or do a ton of research on the infinti system. Your going to need to know what almost every wire does.
