I messed up my Body Mount Nut
Old Mar 15, 2021 | 11:46 AM
Kevin Blank's Avatar
Default I messed up my Body Mount Nut
I need some advice. I replaced my 6 Body Mount Bushings on my 80 Camaro. I messed up the last Bushing by not aligning it correctly and stripped the Body Mount Nut. Its location is the Left side below the drivers seat.
Can I use a Steel Taper Hand Tap to create new Threads in the Nut?
Or maybe insert a Helicoil into the Nut?
Or any other advice to fix my problem? (FYI – I don’t have a welder or don’t have access to anyone who welds).
Thanks for the Help!
Kevin
Old Mar 16, 2021 | 05:48 AM
Everett#2390's Avatar
You may try a tap, it may need to be a bottoming tap as not much room above nut for a standard taper-length tap.
Old Mar 16, 2021 | 08:03 AM
Thanks for the advice, I will look for a 5/8-11 bottoming tap and give it a try.
Old Mar 17, 2021 | 05:31 PM
I successfully cleaned up my stripped Body Mount Nut. First, I used a 5/8- 11 Carbon Steel Taper Tap, followed by a 5/8-11 TiCN Coated High-Speed Steel Bottoming Tap. I tighten up a new bolt and torqued it to 75 ft-lbs.
Kevin
Old Mar 18, 2021 | 05:51 AM
Very good. I forgot to add coat threads with anti-seize for later usage., oh well.
bulldogrsp61
82-92 V8 Tech
16
Apr 16, 2011 01:23 PM
chrshadil
Nov 17, 2009 02:39 AM
chucknasty
Feb 7, 2008 07:46 PM
94Z28SHAKER
Jun 20, 2006 03:17 PM
