headlight wiring diagrams
Does anyone have or happen to know where I could get some headlight wiring diagrams for my '78 z28
350ci 4speed |
RE: headlight wiring diagrams
www.nastyz28.com
good site they should have it there. |
i've been on there a few times and seen the wiring diagram
but i dont know if its the same as mine im really hoping the previous owner didnt screw around alot with it alot of the wires under the dash look no so im not sure do u know of any others? thx |
thats the only one I could find,it should be the same. I rewired my whole front from a 84 trans am and it was the same except for a few extra wires.
thx
i'll try this out again and see if i missed something |
i used my multimeter on the wires goin from the lightswitch to the dimmer switch and the dimmerswitch to the headlights and they all check out (the lightswitch is brandnew) does this mean the dimmer switch is screwed (both my headlights have never worked)
Try to clean all the connections,and replace the headlight, it could be the dimmer switch or just corroded wires. I was getting good readings with a multi meter but the wires that ran by the headers were fried. If you can check a junk yard for f body in good shape and take the whole harness,it may save time and money. The mid 80,s have the same color coded wires so swapping them out will be easy.
