76 Camaro rear tail panel
Old Oct 15, 2012 | 09:39 AM
refderek's Avatar
Default 76 Camaro rear tail panel
1976 Camaro LT
Is the "rear tail panel" the correct piece I need? It's basically a plastic piece the fills the space from the top of the rear bumber to the bottom area of the trunk. It looks like it mounts with a number of screws to under neath the piece just under the trunk.
I know this is a horrible description, but I need help. Thanks.
Old Oct 15, 2012 | 10:28 AM
No, the rear tail panel is the vertical part of the body that the tail lights are mounted into.
What you're looking for are the rear bumper filler pieces. Not available in the aftermarket as far as I'm aware, and very hard to find used. If you ever spot some on ebay (none out there at the moment), grab em fast.
Old Oct 15, 2012 | 02:08 PM
oldman9's Avatar
+1 to what Camaro69 said.
I had to get some large dents out of the sheet metal below the rear bumper. The parts your talking about are circled in the 1st pic.
If you remove the rectangular metal parts in pic number 2 you might be able to get away with only using the middle part under the tag. I think you could fab this up from some 20 gauge sheet metal. Removing the metal blocks tucks the bumper in almost 2- 2 1/2 inches.
Attached Thumbnails 76 Camaro rear tail panel-2-28-.jpg   76 Camaro rear tail panel-3-19-.jpg
77maro
Jul 22, 2014 07:13 PM
bondoman1974
Jun 8, 2014 09:25 PM
Viking
May 28, 2012 04:18 AM
tb04512
Feb 19, 2012 04:17 PM
middleagecrisis
Oct 31, 2007 09:41 PM
