wondering about hp of a 75 camaro
Old Mar 10, 2014 | 12:03 AM
  #21
jimm418's Avatar
also they were using a 15w-40 oil why would they use such a thick oil in it? i live in michigan idk if that might be why
Old Mar 10, 2014 | 08:10 AM
  #22
YAV8's Avatar
If the cam is a flat tappet then you must run a diesel oil with zinc in the additive package. If it was hyd. roller then any 5w or 10w 30 would be OK to run.
Old Mar 10, 2014 | 09:12 AM
  #23
jimm418's Avatar
its a crane roller cam
Old Mar 10, 2014 | 09:50 AM
  #24
As mentioned, a roller can use any oil. I used to use diesel oil, but it too has now had most of the zinc removed, so using diesel oil for flat tappet cams no longer works as well. I now use Brad Penn oil for all my old flat tappet engines. It's a little more money, but cheaper than buying 5 qts. plus zinc additive. I get it for $75 a case at several local suppliers.
Old Mar 10, 2014 | 10:16 AM
  #25
I use STP oil treatment, which has ZDDP that brings current day oils back to the "good old oil" specs. How many quarts are in a case of that Brad Penn oil?
Old Mar 10, 2014 | 04:42 PM
  #26
YAV8's Avatar
DIESEL oil STILL has the ZINC in it, they have not taken it out like the car oil.
Old Mar 10, 2014 | 04:57 PM
  #27
jimm418's Avatar
ok will then thats solved and also im putting on a edelbrock e street efi system its gonna be a driver and the carb is to much up keep
Old Mar 10, 2014 | 09:55 PM
  #28
YAV8's Avatar
I can think of a much better use for the $2000+ for the after market efi. Not to hard to get a car started with a carb and a electric choke. Step on the gas peddle once and turn the key and car starts.
Old Mar 11, 2014 | 12:32 AM
  #29
jimm418's Avatar
will right now push pedal about 20 times turn key and carb goes poof few more pumps will start then stall have to do this a few times to get running when u do get it warmed up u cant put it to the floor will stall out and go poof again but if u slowly push on the gas it will rev up without dying out also one day after running a lil while shut it off and it kinda tried to keep running
Old Mar 11, 2014 | 07:39 AM
  #30
YAV8's Avatar
Set the timing and spend $300 for a new carb and give that a try. As always a little maintenance goes long way.
