Steel motor mount opinions
I had solid mounts on mine for a while, not worth the vibrations in my opinion. I switched over to urethane mounts, which have an interlock so they cant pull apart anyway. Urethane mounts are almost overkill for a 305. lol
I'm with Camaro 69,overkill for a 305. Stock mounts for a smallblock should be fine but urethane would be the ticket if you want stronger.
I run the "Prothane"urethane mounts in my '01 SS,they vibe a bit more than stock but not bad and my car is cammed with a stick shift etc. making a lot more power than a 305.
