Victor 454
Old May 7, 2012 | 12:55 AM
flyarmyhooks's Avatar
Default Victor 454
Hey everybody, I just purchased a 77 (minus engine), and am looking at dropping a Victor 454 under the hood. Does anybody know of any reason this would not work? This is my first engine replacement, and I don't want to get ready to drop this new block into the mount, just to find it won't fit!
Any thoughts would be greatly appreciated!
Old May 7, 2012 | 05:37 AM
5time F's Avatar
If it has AC it might not fit... you might have to do the AC delete mod!
Welcome to the Forum!!
Old Sep 3, 2012 | 01:06 PM
Mr.Bill's Avatar
Beware of hood clearance when using a BBC, Be sure to stick with a low intake, I have a 468 in my 72 and a 4" cowl hood and still had clearance issues using a 14x4 inch air cleaner.
Bill
Old Sep 3, 2012 | 03:05 PM
A2TURBO's Avatar
Banned
it depends on how tall the valve covers are also watch the brake booster! they do fit tho we are putting on in our 77 which had ac deleate in progress those are the two places we are close so finalizing the ac deleate and going to a 9"booster otherwise full length headders fit as well
Old Sep 4, 2012 | 08:34 AM
The heater core outlets can also be an issue, and the low valve covers will clear, but taller will require the core to be flipped 180 degrees and new holes cut in the heater box.
You'll want the larger 31" radiator, and make sure it's either a 4 row, or two one inch rows. The stock smallblock mounts will work, and the hoses will need to be shortened, or buy new hoses for a BBC Camaro.
The booster can be swapped to a smaller brake booster, if you do need more clearance.
350rs
Nov 23, 2007 04:20 PM
