Sluggish get up and go
Old 12-30-2008, 03:12 PM
fleshman77's Avatar
Default RE: Sluggish get up and go
Thanks Bro
Old 01-07-2009, 08:11 PM
fleshman77's Avatar
I found that there is a bar missing. It goes from like a 5 inch diaphram by the distributor to the carb. Does anyone know what that link is called? im thinking this is another reason why when i punch it, it hesitates.
Old 01-07-2009, 08:28 PM
fleshman77's Avatar
http://s415.photobucket.com/albums/pp232/fleshman77/
hopefully this link works. this is what i am talking about so you can get an idea of what it is that im talking about.
Old 01-07-2009, 10:35 PM
That's part of your cruise control. Having it disconnected from the carb will have no effect on what you're experiencing. There are some vacuum lines that are connected as part of your cruise control operation though, so you might want to inspect for any open or cracked hoses. Also check under the dash on the brake pedal assembly for a vacuum "release" switch which is part of the cruise. Stepping on the brake pedal "breaks" the vacuum connection and disables cruise control.....real hi-tech stuff!!! The vacuum hoses to it, or the switch itself could be leaking. From the looks of your engine, it appears like it's never been touched, or very little. That can be good for one reason and bad for another! While you're at it, check All your vacuum hoses for breaks, cuts, or loose fits. Having a lot of vacuum hoses that are loose at the fittings can add up to one big leak.
JonnyRade
03-31-2015 01:45 PM
thedoc4189
04-14-2012 09:05 AM
jurmy2
09-04-2009 04:35 PM
baseballer91
04-04-2008 01:39 PM
auSStin
LS Series Tech
08-29-2006 01:53 PM
Quick Reply: Sluggish get up and go
