Single or double roller timing chain
Old Oct 2, 2010 | 02:43 PM
1976camaro's Avatar
i am going to get the installer but the thing is when i use the remover tool it wore out the first thread and the second one i think but i still got the retaing bolt on...so you think that the installer kit will not strip it..also how would you recomend putting the chain on
Old Oct 2, 2010 | 05:04 PM
Hopefully you only mushroomed the first thread a little. Otherwise you'll need to run a thread chaser into the hole to fix the threads.
Watch the harmonic dampener install video. I would also put some oil on the nut and thrust washer to help it turn easier.
The second video goes through cam and timing chain/gear install. Make a note that the engine is upside down.
The one thing the guy didn't do is use a torque wrench on the bolts, something I wouldn't recommend for a beginner.
http://www.youtube.com/watch?v=Ex_yJ...eature=related
http://www.youtube.com/watch?v=Zr_n0cL46NM
Old Oct 3, 2010 | 02:46 AM
1976camaro's Avatar
so should i use the tourqe wrench or no and how do you think i should put the chain on since its not upside down
Chevy101
May 25, 2011 05:00 PM
anthony7888
Nov 13, 2010 08:08 PM
JordanN
Aug 23, 2010 07:13 AM
KoRN_Munky
Dec 31, 2006 08:02 AM
Z28man
Oct 6, 2006 04:13 PM
