Problems with my 78
Old Sep 10, 2009 | 09:28 PM
Cs78's Avatar
Default Problems with my 78
I recently had my carburetor rebuilt after my car stalled while driving. Now everytime I press on the gas petal the car stalls and almost dies. Any suggestions?
It's a 78 with a 350
Old Sep 10, 2009 | 09:56 PM
Y2K's Avatar
Y2K
More info needed,what carb? manual trans or auto?
Manual,vacuum or electric choke?
Motor stock or modded?
Old Sep 10, 2009 | 10:44 PM
Cs78's Avatar
It's the original stock 350 with the stock carb and no mods yet. auto trans
Old Sep 10, 2009 | 10:56 PM
bad accelerator pump or ignition advance is not working. could be choke but that should go away when the motor warms if its the choke not closing when cold.
Old Sep 10, 2009 | 11:51 PM
Float level might be set too low also.
Old Sep 11, 2009 | 02:40 PM
Y2K's Avatar
Y2K
Could be the choke closing when it's not supposed to also,pretty common with q-jets.
Who did the rebuild? might not be a good job.
Old Sep 11, 2009 | 05:03 PM
Hmmmm....any chance the carb wasn't the culprit in the first place? Could be. Another possibility is your mechanical fuel pump might be bad. Is it leaking at all? A pump can be bad without leaking, but a leak is a sure sign.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
