Heads/pushrods
Old Feb 16, 2012 | 09:25 AM
Shalamara's Avatar
March 2013 ROTM
Default Heads/pushrods
Had this in another section but got no response so I'll try here in 2nd gen.
The motor in my 78 camaro was a 1988 TBI 350 out of a chevy truck (195hp). It has an Eldelbrock manifold and 600cfm carb and 1 5/8 headers and 2.5 inch exhaust (So I don't know what I have for hp now). Intake valves on these motors were 1.84 not 1.94. Other than this, motor is stock. This is a non roller motor.
Now, I have a chance to purchase a set of 062 vortec heads with after market manifold for a good price. If bought, I know there are other things that need to be done and checked first. BUT, If old heads were taken off and vortec heads and manifold put on, is this a straight swap? If not what else needs to be done? Can same push rods be used or are they the wrong length?
Would I gain anything by going to these heads? Would they be better for a future build?
Old Feb 16, 2012 | 03:56 PM
First off it was great to finally meet you and your wife today!
You can bolt them right on with no problem as long as you have the intake to match. Same puhrods will work. High lift cams will create spring bind if they're over around .440 lift. Umbrella seals, or .050" keeper will allow more lift without seal damage. You'll also need self aligning rockers if you go to higher lift later.
Vortec heads should be 1.94/1.50 valve sizes, and thye flow around 227/140 cfm at around .400" lift.
Here's a link to everything you'd ever want to know about Vortecs from 2QuickNova's Racing site:
2QuickNovas.com - Chevy L31 Vortec Heads
Steer clear of Vortecs with head #10239906
Old Feb 16, 2012 | 06:17 PM
Vortecs will need self aligning rockers regardless of cam.
Old Feb 16, 2012 | 08:57 PM
Don't they have them in stock form?
djsquare1
Apr 28, 2013 01:51 PM
Shalamara
Aug 15, 2012 07:25 AM
ScottD
Jan 1, 2010 07:07 PM
brenkate
Oct 22, 2007 12:28 PM
gotalcoholmanup
May 24, 2006 11:15 PM
