Harmonic Balancer wont go on
Old Feb 4, 2011 | 12:37 PM
  #21
1976camaro's Avatar
ok.. do you know where i can get a crank gear installer for cheap or rent one... autozone doesnt rent them
Old Feb 4, 2011 | 12:58 PM
  #22
You should be able to tap the crank gear the way you did, or with a steel pipe, without needing a lot of force. If you have as much crank showing, as how wide the damper hub is, then the problem is with the damper or crank. But if you have less crank showing, something isn't right with the gear install. That's why you want to measure the two to compare.
Old Feb 4, 2011 | 01:02 PM
  #23
StoveBolts's Avatar
DO NOT use the stock bolt to pull the harmonic damper on, you take a big chance of stripping out the threads in the crank.
Eh, that's why they make heli-coils
There is a proper installation tool to use for this job. Places like AutoZone will loan the tool out, with a refundable deposit.
Sound like a much safer way
Old Feb 4, 2011 | 01:24 PM
  #24
1976camaro's Avatar
well the damper goes over the crank and into the timing cover... their is no crank showing yet the damper isnt on all the way and its stuck
Old Feb 4, 2011 | 03:01 PM
  #25
And sledge hammers!!!
Old Feb 4, 2011 | 03:04 PM
  #26
Yes, but once the damper slides past the seal, you can't see how much of a gap is left between it and the gear. You need to measure how much crank is there against the damper hub, otherwise you're just guessing what you have.
Old Feb 5, 2011 | 12:27 AM
  #27
1976camaro's Avatar
so should i take the timing cover off and do it like that to see how much their this... ima take it home and put it in my laundry room where its warm so maybe that will help it expand if it shrank
Old Feb 5, 2011 | 01:26 AM
  #28
if you want to get it off then you could try a hair drier on the hub and shield the crank as best you can. that way the crank will not expand with the hub so much. stuff something in the center hole so the heat wont get to the shaft. do you have a puller?
Old Feb 5, 2011 | 02:57 AM
  #29
1976camaro's Avatar
ya i have a puller the problem isnt getting it off its getting it on
Old Feb 5, 2011 | 06:43 AM
  #30
ok i thought it was stuck. you will be surprised at how much difference it makes just by heating the hub.
