Fan shroud and radiator support
Old 09-25-2012, 02:22 PM
Tomg303's Avatar
Default Fan shroud and radiator support
Hey guys I need a radiator support and fan shroud for my camaro because it was originally a I6. I was wondering if parts off a 70's pickup would be compatible with the car. I pulled the radiator of a later 2nd gen Z28 but there was no shroud or support. Will I have to buy a camaro specific shroud and radiator hold down.
Old 09-25-2012, 03:19 PM
No, there are other GM radiators and shrouds that will fit, but the radiator supports wont interchange from a truck. I actually had a radiator from an early 80's BBC truck in mine for awhile, and the shroud should work too. Only thing you might have to do is open up your core supporrt if you get the wider radiator to let more air in. The core supports are marked out with a ridge where they need opening, so once you test fit the radiator you'll see how it needs to be opened up.
I've cut several on BBC swaps, and I use a jigsaw or sawzall with a metal cutting blade to open tham along the stamped ridge.
Old 09-26-2012, 02:19 AM
Tomg303's Avatar
Perfect response. Gave me more info then I asked for, and it was much needed. Thanks for your time!
Old 09-27-2012, 12:08 PM
Tomg303's Avatar
So today I went to the salvage yard and asked for the upper radiator support and shroud. The guy argued with me that it wouldn't fit because it was twice as long. I said I would take a chance and he continued to argue. Went to another and they said they could only sell the whole radiator support together. Its killin me. Maybe its time to give into ebay.
Old 05-24-2018, 09:34 AM
So what vehicle should i pull the fan shroud from? I need a new one but i dont want to pay $200. And what kind of adjustments would i need to make
Old 10-14-2018, 10:10 PM
hollywood1336's Avatar
I have a fan shroud from a 1970 Z28 if you are still looking for one.
Old 10-14-2019, 10:45 AM
Default 78 Camaro Fan Shroud needed
I am looking for a fan shroud for a 78 Camaro with original radiator with AC. 305 V8 engine. Any suggestions?
Old 10-15-2019, 05:31 AM
This should be it,check your radiator size before ordering.
https://www.camarocentral.com/1970_1..._p/rad-771.htm
Lee74
70-81 V8 Tech
07-31-2014 07:39 AM
chuckles
02-25-2014 09:46 AM
Harvey
05-12-2006 03:27 AM
89RScammy
04-18-2006 01:14 AM
Quick Reply: Fan shroud and radiator support
