Engine manufacturer?
Old 12-26-2018, 11:07 AM
nny462's Avatar
Default Engine manufacturer?
I picked up a 77 Camaro that has a stroker in it. I'm trying to add a vintage air kit, but need to first figure out what compressor is compatible with the engine. Any tips on how I can figure out who the manufacturer of the engine is so I can determine what compressor is compatible?
Thanks - Jon
Old 12-26-2018, 06:15 PM
Y2K's Avatar
Y2K
Y2K is offline
Not quite sure what you mean here, Chevrolet would be the manufacturer, the stroker part would be a different crank rods and piston kit for the stock Chevy block typically.
Even a new crate engine would typically be a Chevy block and an AC pump for a Chevy small block 77 Camaro application should be what you need.
Old 01-11-2019, 02:02 PM
Thanks - Jon
The important criteria to know when ordering the AC bracket, is it a
SBC or BBC? does it have a short water pump or long pump? What side do you want the compressor on?
The Vintage Air kit work best with Sanden style compressors, The brackets that we sell are designed to mount Sanden compressors. If you give our sales team a call (210-654-7171)with your the engine criteria above we will set you up with a compressor and compressor bracket that will work with the Vintage Air system.
Old 01-13-2019, 07:26 PM
You can tell by looking at the picture that he has a small block with the long water pump
Old 01-14-2019, 02:03 PM
Zspoiler's Avatar
Just get one for a 1977 Camaro with a small block Chevy.It doesnt matter if its a stroker engine
DrvLikHell
05-23-2016 06:58 PM
Randy Bilyea
11-06-2012 08:51 PM
v8xj
07-25-2012 01:52 PM
BigRegUK
09-22-2009 09:38 PM
herestolife1000
04-20-2008 02:08 AM
Quick Reply: Engine manufacturer?
