Dash Gauges
Old Jul 14, 2010 | 08:46 AM
80z28guy's Avatar
Default Dash Gauges
I was driving home from a car show the other day. When I looked down to check my temp all my gauges were not working. The tach is at 3500 rpm the speedo is stuck the temp gauge is stuck in red. Any ideas on what this could be. Checked the wiring and all is intact.
Old Jul 14, 2010 | 08:48 AM
gfrench's Avatar
Did they loose ground?
Factory Cluster? or individual gauges?
Old Jul 14, 2010 | 01:33 PM
80z28guy's Avatar
Not sure if they lost ground. They are factory gauges. Where would I check for the ground on that? I have a aftermarket cluster gauge too but they work. Just thought what the hell would have caused that.
Old Sep 6, 2010 | 10:06 PM
jbe123's Avatar
Have you checked the fuse for the guages?
Old Sep 13, 2010 | 02:56 PM
80z28guy's Avatar
The fuse is fine. The speedo started to work but it's still off since doing the rear end. I think I need all new gauges inside the dash. I think I'm going to try to find one used. I heard something crack inside when the stopped working. So not sure what that was.
blackbeauty1995
Dec 18, 2013 08:33 PM
Vet76te
Aug 2, 2010 06:40 AM
DJTJ
Mar 27, 2008 10:45 AM
pigchunks
Sep 14, 2007 10:53 PM
CamaroKid81
Apr 8, 2007 07:10 PM
