Car just died
#45
You definitely want to put new lifters in if you replace the cam.Makes sense to replace them anyway since they have to come out to change the cam,plus they are cheap,you can get a cam with the lifters at a good price.
#47
^ I've seen it done and it does work but keep looking it shouldnt be that hard to find, worste case senario just buy a new TC cover and it will come with a gasket. I use both, light layer of liquid over the gasket (keeps it in place good to).
Joe
Joe
#49
ok so i have found a gasket for it i was looking under timing chain gasket not timing cover gasket....anyways the problem i have with my timing chain and gears now is that the gears are so broken i cant find the center marking on the gears how can i get it to top dead center with broken gears or can i do it with the new chain and gears
