Air filter diameter
Old Oct 6, 2012 | 11:50 PM
Tomg303's Avatar
Default Air filter diameter
Quick question. How do you determine what size air filter to run? I'm looking at either an edelbrock 10" or 14" pro flo
Old Oct 7, 2012 | 12:43 AM
The short answer is at a minimum, a 10" dia. x 3" tall, or 14" dia. x 2" tall (3" would be better).
The long answer...
Square inches of filter needed: C.I. x Max rpm divided by 20839
So, 350 x 6,000/20839 = 100 sq. in.
That's based on the CFM requirement of the engine at 100% volumetric efficiency, which your engine is not. Yours may be closer to .80, giving you 80 sq. in. needed.
Then get the circumference of the filter x the height to figure the total square inches.
14" x 3.1416 = 43.98". x 2" tall = 88 sq. in., or 3" tall = 132 sq. in.
You can do the math for a 10" filter. Be sure to show your work!
Old Oct 7, 2012 | 12:17 PM
Tomg303's Avatar
Thanks! helped a ton
Old Oct 7, 2012 | 02:50 PM
I don't do math. I usually just buy a 14" by 2"-3" thick. Never had a problem with it being too much filter. Just don't get those huge 6"-8" thick filters that the race cars use.
Old Oct 7, 2012 | 02:56 PM
BasicConcepts's Avatar
Technical User
The long answer...
this should be in the stickies
Chevyfan99
Jun 26, 2013 04:41 PM
chewybacca11
LS Series Tech
Oct 19, 2010 02:59 PM
Spartan66
Dec 12, 2008 11:55 AM
baseballer91
Apr 13, 2008 11:28 PM
94 z28
Mar 10, 2008 05:11 PM
