74 Return Fuel line
Old Aug 27, 2010 | 07:55 AM
Tom071's Avatar
Default 74 Return Fuel line
I have a 74 Camaro and I am putting in a crate 383, it has a highflow fuel pump with no return line hookup, can I just cap off the return line at the tank?
Thanks
Old Aug 28, 2010 | 12:42 PM
Are you talking about an electric or mechanical pump? If you're running a carb with a high flow pump, you'll also want to run a fuel pressure regulator to adjust the psi to the carb. Use a return style regulator and hook it up to your return line. The pump will last longer because the fuel will be flowing at a consistent rate that way. Dead-head type fuel setups tend to burn out the electric pump sooner, or wear out a mechanical one sooner. Set pressure at 4.5 psi if an Edelbrock carb, and 6 psi if a Holley.
Old Aug 29, 2010 | 06:20 AM
Tom071's Avatar
its a holly/Summit Carb with a recomendation of 7psi and a mechanical pump rated at 7 psi
fire43f
Apr 26, 2013 07:03 AM
manslaughter299
Jul 24, 2012 03:17 AM
91TealRS
Aug 31, 2011 08:35 PM
craby
Jul 20, 2010 12:17 PM
350rs
Jun 19, 2007 10:12 PM
