Needing some help id a t10 trans
Old Feb 10, 2013 | 08:37 PM
BradHall's Avatar
Default Needing some help id a t10 trans
I purchased a 1978 camaro z28 without a transmission, and have been looking for a t10 4 speed to go back in it since it was a stick shift car. I found a 4 speed t10 I think but want to make sure it is the correct one for my vehicle. The numbers on it are 1304065903 mlt4465 5 5 81
Old Feb 11, 2013 | 12:00 AM
The 903 means it's an aluminum case Super T-10. 5 5 81 is the casting date, May 5, 1981. The grooves on the input shaft will tell you what gear ratios it has: Borg Warner Second Design ST
Old Feb 11, 2013 | 07:51 AM
BradHall's Avatar
How can you tell for sure if it is for a chevrolet? I honestly am clueless about borg warners and trying to scrap money together on a tight budget (also restoring 51 chevrolet pickup and a old vw sandrail) and don't want to buy the wrong trans. I couldn't find any top numbers, it was blank there and the only other numbers I find are on the bottom and they are either fc4 or fpc4. Thanks so much for your help.
Old Feb 11, 2013 | 08:39 AM
The Super T-10 was only used in GM "F" and "A" body cars. I don't know of any distinguishing features, other than the presence of a partial VIN to show what kind of car it was put in.
Here's more info on the trans: 10 Ways To Improve A Super T10 - High Performance Pontiac Magazine
Old Feb 11, 2013 | 10:31 AM
If it's a Super T10, it will fit your Chevy. If it's aluminum (and sounds like it is!) it's a Super T10. If you have a clutch and pressure plate already in the car, be sure the clutch disc is fine splined to fit the Super T10! If you didn't have a Super T10 before, the old disc will be coarse spline and wont work.
Old Feb 11, 2013 | 10:40 AM
It is an aluminum Super T-10, per the "903" code on his case. Gee this sounds familiar!
draven666
Dec 7, 2014 11:17 AM
!WildChild!
Oct 17, 2011 08:22 PM
Bryan09
70-81 V8 Tech
Nov 23, 2009 12:37 PM
mario82z28
Jun 9, 2009 10:12 AM
