Offset Spindles
Old Oct 15, 2022 | 09:59 AM
F-body-bowtie's Avatar
Default Offset Spindles
Hi all,
Wondering if anyone is aware of any spindles that may be available for narrowing the track of the front wheels. I have a stock control arm and spindle set-up with some lowering springs installed. This has resulted in the front tires rubbing on the inner fender when going over larger bumps. I need to have the wheels move inward (narrower) by about 3/8" - 1/2"
I'd prefer not to use different rims on the front to accomplish this offset / narrowing but wasn't sure if there was a different way to do this. I could re-position the pivot point on the lower control arms but then that would also change the positioning of the spring pocket which may cause interference issues.
It is a 1981 Z28 by the way
Any ideas from others are welcome ... thanks, Dale
Old Feb 11, 2026 | 12:25 PM
sallyromime01's Avatar
One outer spline should lift the rear end around 6cm or 2,36 inches. One inner spline should lift it with 5,5cm, or around 2,16 inches
PSmolchek
Dec 17, 2016 08:48 PM
Speener
Oct 4, 2014 11:59 AM
acii
Dec 6, 2012 11:57 AM
ENTRDRGN
Apr 8, 2011 10:27 AM
maxxiepad
Feb 7, 2007 02:28 PM
