Help.
Old May 17, 2010 | 01:48 AM
Twinky_Bomb's Avatar
Default Help.
I was wanting to add a little bit of a lift to the back end of my '81 z28, but I don't really know anything about lifts. I just want the back end to be slightly higher, and put wider tires on it for that drag car look. Would I do a body lift, or a suspension lift? How many inches? Or would just adding wider back tires lift it on its own?
Thanks.
Old Jun 6, 2010 | 05:35 PM
Buckeye69's Avatar
TB,
By some air shocks, that is one way, and maybe the easiest for you. This would allow you to get the most out of it by putting as much air in as needed to achieve the ride height your looking for. And they are not that expensive.
