Dumb question
Hello, I just got my new leaf springs and with them, new bushings and hardware. I want to install them but I am wondering about how to situate the car in reference to the jack and stands....I need to jack up the rear end and place it on jack stands, correct? or is there something else I should do when replacing the leafs? Also, the spring mounts that attach towards the front of the car are accessed when the two bolts that affix it to the car via the mounting plate are removed, correct? I see no other way to removed the through bolts that attach the spring. In fact, I don't even see the through bolts so I guess you have to remove the two small bolts to gain access? Thanks in advance
tattoo400,
You'll find there's 3 bolts that hold the front spring plate, and they are tough to get any penetrant to the threads, as the nuts are hidden under the floorpan. They often seize up if you live in a area with much road salt. If they are, then you'll need to cut access holes in the floorpan to hold the cage nuts, or spray them.
When changing springs you need to jack the whole car up and put jackstands near those spring plates on the rear frame. Then you'll need a floor jack to put under the differential so you can support the load off the springs and keep them from dropping when unbolted.
You may need to cut the rear shackle bolts to replace the springs, and install new repro, or aftermarket shackles. I built my own, as it was cheaper, and easier than getting repros, and aftermarkets were all too long.
And now you have officially set the one day record for most posts with no content! Please submit your info to collect your prize!
I think he's looking for more help than "go read up".
tattoo400,
tattoo400,
Don't forget some jackstands under the rear framerails along with the ones under the rear diff. And you won't have to necessarily have to cut holes in the floor for the j-clips holding the front leaf spring mount. If they are stuck, grind the head of the bolt off and get the spring out of the way and then you can deal with the stuck bolt and you won't have to fix the hole you put in the floor to get to them. I just went through this. But the rest of the info is spot on.
I've seen a number of lowered 2nd gens, and depending on how it was done, or how low they went, some look very nice.
