Project Camaro 75
Old Nov 24, 2021 | 06:55 PM
Brad703's Avatar
Default Project Camaro 75
I recently bought a 75 Camaro and want to swap and ls 5.3L into it but my trans is a th350. Do I need to swap my trans to a 4L60E or is there a way I can mount the ls to the th350 thats still in the car?
Old Nov 24, 2021 | 08:04 PM
Old Nov 24, 2021 | 09:53 PM
I would not think it would be worth it. Not all TH350 are the same. If a TH350 came from the factory behind a 150 hp engine then that was what it was configured to handle. Putting that trans behind a 300 HP LS motor should be considered a temporary solution. It is less of a concern if you have an open rear, The one wheel peel cannot put down the 300 ponies so there is much less stress.
ken69rs
70-81 Transmission & Differential
Oct 30, 2020 11:06 AM
juantoids
Jan 18, 2015 09:16 AM
Ridechevy03
Jan 27, 2012 06:06 PM
mc82
67-69 V8 Tech
May 18, 2010 11:32 PM
91CAMARORS305V8
Dec 4, 2008 03:07 PM
