New Build Thread?
Old 01-12-2012 | 12:49 PM
rydeer's Avatar
One area that I was concerned about, was the timing marks. They are within 1/2 deg.
  #302
Old 01-12-2012 | 08:02 PM
Heck the tab can get bent a little and be farther off than that! Sounds like you're really close!
  #303
Old 01-12-2012 | 08:07 PM
Originally Posted by rydeer
While that cooks I'm starting on the engine. I don't expect any drama. Needs a cleanup and paint. I changed the cam without dropping the pan. It leaks a little. But it ran good and had good oil pressure. I'll check everything out while I can.
Nice and clean like I expected in side.
Are you going to replace the pan seal while it's out, or?
  #304
Old 01-13-2012 | 04:30 AM
rydeer's Avatar
Yes I'll go through everything. Check bearings etc. It's cheap and easy now.
The timing mark I can be off more just by leaning my point of view a little.
  #305
Old 01-13-2012 | 12:14 PM
rydeer's Avatar
Little bit o drama. When I pulled no 8 ex rocker, The spring clip that hold the lifter together was gone. I found it in the pan. 2 pieces but complete.
It seems as though it only holds the lifters together when there is no load.IE on the bench. I took a clip from an old lifter and put it in this one.
Attached Thumbnails New Build Thread?-002.jpg   New Build Thread?-001.jpg   New Build Thread?-003.jpg
  #306
Old 01-13-2012 | 12:23 PM
bad436z28's Avatar
wow nice find,i bet ur glad u found that before putting the engine in,never seen that happen before.maybe i better check mine,just kidding mines a solid roller,but i sure im gonna check all the roller bearings for excessive play,even though there practically new.
  #307
Old 01-14-2012 | 12:33 AM
I found the tip of a push rod in the pan before. Never had an issue with the engine, just tore it down to check the bearings and there it was.
  #308
Old 01-14-2012 | 03:08 PM
rydeer's Avatar
Yeah I had no issues either. Only about 500 mi. on this cam and heads.
I did some measuring today. ,060 over nice and round. I'll get some plastiguage tomorrow and check the bottom. Everything is nice and clean almost no ridge at all.
Rering kits w/all bearings and gaskets are less than $100.00.
I cleaned and did some powdering.
black mtr mts.
the V covers were candy red over the orig alum. The alum was real splotchy and it showed. I'm doing chrome with ered over. I'll leave the ridges and the lettering chrome.
chrome on the intake.
Attached Thumbnails New Build Thread?-003.jpg   New Build Thread?-004.jpg   New Build Thread?-005.jpg   New Build Thread?-002.jpg   New Build Thread?-006.jpg
  #309
Old 01-14-2012 | 03:59 PM
That's kinda what I did with my old Eddys too. Painted the ribbed area red, then wiped it off with reducer and polished the high edge:
  #310
Old 01-14-2012 | 04:19 PM
rydeer's Avatar
Looks good. I have too many dings and stuff in the sides to remove the red. They really show up chrome.
Quick Reply: New Build Thread?
