CRU!NCH TIME - 73 Z28 Build
#131
Learned something new today! Thanks! I wasn't aware the 4th gens had that set up to work that way. Sounds like a poor design to me.
#132
not trying to hijack, just to add to your statements.
Im eagerly awaiting more pics of your build.
#133
It was not as well thought out as it could have been. simple adjustments in design could have fixed alot, but its worth it for the power gains. but if the water pump blows the optispark ( distributor) is under it so you get to replace both, like this Optispark Replacement - DFW - Corvette Forum
So here is some pics of the suspension installed and the new opti-spark.
here is a couple closer ones.
a good shot of the coil over.
here is the old opti I before I removed it. I forgot to take a pic of the water pump installed but You can see it's removed.
I had a screw that was out just hanging out inside the distributor housing and the other one was loose. here it is screwed back in
here is the new distributor installed. it's all black looks nicer that the OE one. not that it matter since you can't see it anyway once the pump is on. I would say that the cap, rotor, and water pump had been replaced recently. They still look new. The reason I had to replace the whole distributor is the optical sensor is bad. and they don't sell just the sensor.
Water pump
After I hooked up the wiring and turned the key I couldn't help but notice the mileage that is on the instrument cluster.
I expected it to have a lot more. but Of course the mileage on the cluster means nothing since I just bought it off eBay from some wreaked Z28. I'm trying to decide what to set the mileage to. The mileage off the old cluster, the miles from the engine or zero. I have a Tech 2 and access to GM programming software website. So I think I'm just going to set the mileage back to zero when I get this thing back on the road. It will be like a new car why not start over? Well that's all for now till I can figure out how to get this video of it firing up, off my phone and on here.
#135
No joke your build has got me looking into 70-73 trans-ams to do something similar.
My wife's car will of course come first but... Its gonna happen...
#138
yea man i think there were a lot more people interested in this build then you thought. i love the newer style gauge cluster in the old car. but i did notice you have a service engine light on, i'm thinking maybe you just need an oil change and it'll go away.
#139
sweet it's good to know I'm not doing this just for me to look at LOL. Half the fun of building a car is knowing that other people are seeing and take interest in what your doing. Not to mention getting any help when an issue comes around. Once the GF goes back to school I'll have more time to put in some work on the car and I'll let the updates flow.
I know right, but yeahh got love that cars now days have to tell us when to change the oil lol. However I haven't even checked to see if there is any codes stored, I'm sure there is a bunch I know atleast three. VATS code, oil pressure sending unit is busted and fuel sending unit not hooked up yet.
Well thanks for reading I look forward to your guys post and progress.
