Cobalt Blue 79z28
Old 03-06-2012 | 12:00 AM
bad436z28's Avatar
yeah there a pain in the but,now i gotta lay a little adhesion promoter before i prime it,best if u can just scuff and shoot it,but mine had lots of cracks in the paint everywhere.
  #462
Old 03-06-2012 | 09:54 AM
I read your adding a flex additive. I never did on my 78 and its still not cracked. In fact its sitting in the garage with no support under it so it collapsed but still no cracking.
  #463
Old 03-06-2012 | 04:00 PM
bad436z28's Avatar
i decided dont to use the flex additive,im painting with urethane they said it should be fine without it,but did use a adhesion promoter on the bare spots,got it all primed today doesnt look too bad,much better than it did,still have a few spots im gonna need to touch up with some spot putty,but overall much better.
  #464
Old 03-06-2012 | 11:54 PM
I need to get to work.
  #465
Old 03-07-2012 | 10:54 AM
bad436z28's Avatar
yeah brother u dont want me catching up,but ur way ahead of me,so take ur time ur cars awesome an inspiration to make mine perfect.it came out pretty good i just have a few spots im gonna need to use spot putty on,other than that its ready for block sanding.so now its on to the passenger fender that one should be alot easier,its unbelievable how good of shape my fenders are in not a spot of rust anywhere,not even the back side.
  #466
Old 03-07-2012 | 07:44 PM
bad436z28's Avatar
another beautiful day in michigan was 65 degrees out,got another panel done today my passanger fender spent the day sanding the fender by hand i always sand my panels by hand,i feel i can get a much straighter and smoother panel that way,im not very good with a d.a sander always sand to much off.so i got my fender all sanded and smoothed out,hardest part was all the rock chips at bottom of the fender ended sanding that down to the primer.in one hour i will be going out to lay my last coat of primer then its on to the next panel,yahhhh!!!!.
By bad436z28 at 2012-03-07
  #467
Old 03-07-2012 | 09:14 PM
bad436z28's Avatar
ell just layed down my last coat of primer on the fender,came out pretty good,now its ready to block sand so on to the next panel,my door jam.
  #468
Old 03-08-2012 | 10:00 PM
bad436z28's Avatar
was alot colder today but still managed to get a little done,finished sanding the door jams,and cleaning them really good and wiping down with wax and grease remover,now there ready for primer that will get layed on saturday,found my first spot of rust today hiden under the paint by the rear window,but cleaned up easy so no biggie.
By bad436z28 at 2012-03-08
  #469
Old 03-09-2012 | 10:51 AM
Not bad. Easy fix. How are the corners at the windshield? That was the biggest spot I look for on any second gen.
  #470
Old 03-09-2012 | 12:09 PM
bad436z28's Avatar
yeah that was the first place i checked as my 80 was rusted bad on the drivers side bottom of windshield this one is rust free there,windshield must have a good seal on this one.
Quick Reply: Cobalt Blue 79z28
