Cobalt Blue 79z28
Old Feb 5, 2012 | 01:25 PM
  #351
bad436z28's Avatar
well found a rebuilt super10 for 400 bucks sounds like a good deal,also found an m-21 for 850 on ebay but condition is unknown,also found an m-21 for 450,the super10 and m-21 are local so i can see them before buying,not sure yet wich way to go.then i gotta find me a good clutch,maybe ram or something similar what do you guys recommend for a clutch.i dont want a race one there to harsh for street driving.
Old Feb 5, 2012 | 02:53 PM
  #352
I'd go the Super T10 rebuilt for $400! That's half of what they get around here for a rebuilt ST10.
Centerforce, Ram, Hayes, and McLeod all have decent street/strip diaphram pressure plates in avaerage price ranges of around $130-$175. Zoom is probably the most reasonably priced at under $100 for something decent in a diaphram style.
All of them sell combos for around $300 for clutch, pressure plate, alignment tool, and bearing. I'd go with the combos, so you have it all matched set. Not sure if you have 11" or 10.5" flywheel, so can't direct you without knowing which.
Old Feb 5, 2012 | 03:06 PM
  #353
bad436z28's Avatar
yeah im probably gonna go with a 11 inch flywheel,those trannys didnt come with bellhousing but should be able to pick one of them up pretty cheap,i will defenately go with the combo so everything matches,is that zoom one pretty good even though its cheaper,or should i go with centerforce always had good luck with them in my 5 speed pontiac formula,yes i know them t-5 are junk kept blowing up the bearings had to have it rebuilt 3 times and it only had a 305 tpi.yeah that super 10 the guy says it has 0 miles on it,he had it rebuilt to put in his 68 camaro then decided to go to a 400 turbo automatic.
Old Feb 5, 2012 | 08:56 PM
  #354
bad436z28's Avatar
i have to buy a new flywheel any recommendations should i spend the money and buy the good one or is a cheaper one ok.is the second series t-10 the best or are they both good,i think the second design came in about 74.the one the guy has for 400 is from a 68 camaro.
Old Feb 5, 2012 | 10:26 PM
  #355
Better look and see what 11" bell housings are going for. As far as i know they are around 150-200.
Old Feb 5, 2012 | 11:31 PM
  #356
bad436z28's Avatar
150 to 200 wouldnt be bad i could settle for a 10.5 inch too,damon what kind of clutch u running in urs,im thinking of getting the zoom as they have there flywheel to match also.there flywheel is less than 100 bucks.
Old Feb 6, 2012 | 05:28 AM
  #357
rydeer's Avatar
Cobalt blue?? I thought he new body was black?
Old Feb 6, 2012 | 08:42 AM
  #358
??????? Me too!
I don't know much about Zoom, and I'd probably go Centerforce. I'd also go with a 11" and get something that's around 2800-3,000 lb. rated pressure plate, unless you don't want a heavy clutch pedal. If your engine has nearly 600 hp, I doubt a standard clutch kit will hold it. The Centerforce dual friction clutch/pressure plate kit is designed for higher HP engines, and should work for your 583 rwhp. It will set you back over $300 for the kit.
I wouldn't get caught up in the hype of exotic flywheels, unless you're going to race a lot. I'd just get a 11" flywheel that fits, and save the money. 11" flywheels can go from under $100 for a Zoom to over $400 for one of the exotics. Most run around $200-$230.
Old Feb 6, 2012 | 01:12 PM
  #359
I have a stock 11" flywheel balanced. I run a Center Force Duel Friction clutch. The pedal is stiff from what I remember. I haven't driven that setup in almost 15 yrs.
Old Feb 6, 2012 | 01:45 PM
  #360
bad436z28's Avatar
it looked blavck in the picture he sent to my phone,but when i had chance to check it out for a few minutes on sunday it was red,but not for long the paints gonna get stripped and painted bright cobalt blue,as i already purchased the whole paint kit from primer to paint,so wont be red long.
