632ci engine installation in 78 camaro
#91
No the TH 400 with a full manual VB wont. I would run 3/8"/10mm line on the trans. Typical trans pressure is 175-225psi (12-15.5 BAR) if I remember right. I know it wont go past 300psi (20 BAR) unless something is terribly wrong. I did the conversions for you to make it easier to understand the pressure your dealing with. I too would only run a fan on the cooler unless it was mounted somewhere besides in front of the radiator.
I prefer B+M or Hurst. Both are fine. Actually as long as you stay away from the cheaper B+M/Hurst ones, they're all good. But you will need one that shifts PN321. So there's no chance of even using a cheap one. With the money you've spent so far. I would use this...
Question 2 - Hurst make the same pistol type shifter but with the red button on top. This can be used if I decide to go for nitro 572.
Question 3 - Does this shifter will be installed and still using the original center console of the camaro?
Thanks
#92
Most aftermarket shifters can be used in forward or reverse pattern, but if you have a standard pattern it will be like Damon posted-P-R-N-3-2-1. If you were to choose a reverse manual valve body, then the pattern is P-R-N-1-2-3. It's just a matter of which you like, and whether you want to pull back the lever to upshift, or push forward to upshift.
I don't know of any aftermarket shifters that will fit in your stock console. Almost any can be custom fitted, if you have the ability to fabricate mounts and a base plate, but they aren't a bolt in. I put a B&M in my '71 Camaro, and made a cover plate from aluminum to hide the opening after I removed the stock cover.
This what mine looks like:
#93
Just to clear out something please, when we say manual valve body and reverse manual valve body are we referring to the same thing ie: shifting to what ever gear you like manually? I would prefer pulling back to up shift - then I need P-R-N-1-2-3 correct?
#95
I have a Turbo Action Cheetah SCS Shifter, I still have to make a trim piece for around the edge of it. 400 trans with reverse patern manual valve body and 2800 stall speed convertor. It also has line lock and trans brake installed. I don't know what gas mileage is, and don't really care, it's a toy just like having a boat, you add fuel everytime you take it out.
#96
I like the B & M shifter. Looks nice as well.
Just asking the same question:- when we say manual valve body and reverse manual valve body are we referring to the same thing? ie: shifting to what ever gear you like manually? I would prefer pulling back to up shift - then I need P-R-N-1-2-3 correct?
Thanks
Thanks
#99
Hello Guys, Does any one know or used Hydratech Braking system? Perhaps the engine I am planning does not produce enough vacuum, some one recommended Hydratech. This braking system uses the power steering system to drive brake pressure on demand.
Any suggestions please? Thanks
