350/383 stroker kits
I have assembled quite a few using Scat kits, and they were very acceptable. Depending on the application and intended use/rpm's an eagle or BETTER rotating assembly might be in order.
Scat = entry level.. good stuff for the street and occasional drag..
Lunati, Speedmaster, Eagle, Scat, Etc, etc.... Northern Auto Parts can set you up with a basic and decent street 383 rotating assembly kit for under 800 dollars...
https://mechanicguides.com/best-383-stroker-kit/
