1978 z28 5.3 swap
Old Jan 15, 2015 | 02:48 PM
juantoids's Avatar
Default 1978 z28 5.3 swap
Hey everyone. I just picked up a 1978 camaro of Craigslist for 500 bucks. I bought the car since it needed a head gasket job, but as I started the car I notice it had a knock. So that's when I decide to either swap the engine or do a carb 5.3 swap. I've decided to to a carb 5. 3 swap.
To start of I've never done anything like this before. I've read a lot online on what I need as parts to do this swap but I was wondering if anyone has any tips or specific parts I need for this swap? I want this to be a simple and yet affordable swap.
Is this swap possible to do with a budget under 2500? Any tips or I deas will help me alot. I will be starting a youtube channel to show you guys the process of the engine swap and keep you updated
Old Jan 18, 2015 | 11:35 AM
clacia's Avatar
Hello Juantoids, welcome to this forum.
Old Jan 19, 2015 | 09:12 AM
meanstrk's Avatar
If I were in your shoes, I would tear the current motor down first to find out what's causing the knock and then decided to either rebuild or replace.
Welcome!
Old Mar 29, 2015 | 05:36 PM
Rottieiller's Avatar
[IMG]//scontent-ord.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/11030082_1430318640594744_8787272262307150996_n.jp g?oh=8557903061eb1387ad3418849d3a8d9f&oe=55B807BA[/IMG]
Old Mar 29, 2015 | 05:38 PM
Default my BABY
This should be a photo of my Beast
Old Mar 30, 2015 | 09:53 AM
The answer is, it depends on if you already have an engine and trans, and how much you do yourself. From what I see of 5.3 LS motor prices, you'll spend the whole amount and more for a 5.3 engine and trans, and maybe more! If you already have an engine/trans, then you'll be able to do the swap under $2500 if you do the work.
If the plan is to convert to a carb then you'll still need a stand alone computer to run the transmission. You may be able to adapt to an older trans, but that would cost more than getting the computer to run a newer style trans that bolts right up to a 5.3 LS.
Of course the cheapest route is buying or building a SBC 350, and skipping all the swap of engine and trans. So if the budget is tight, I'd stay with a SBC, and keep it simple.
scotty1736
May 24, 2013 04:31 PM
rubberduck
Jul 31, 2011 08:25 PM
SurfnSkate
70-81 V8 Tech
Jul 30, 2009 04:03 PM
350z28
Jun 17, 2007 04:22 PM
