1978 z28 5.3 swap
Hey everyone. I just picked up a 1978 camaro of Craigslist for 500 bucks. I bought the car since it needed a head gasket job, but as I started the car I notice it had a knock. So that's when I decide to either swap the engine or do a carb 5.3 swap. I've decided to to a carb 5. 3 swap.
To start of I've never done anything like this before. I've read a lot online on what I need as parts to do this swap but I was wondering if anyone has any tips or specific parts I need for this swap? I want this to be a simple and yet affordable swap. Is this swap possible to do with a budget under 2500? Any tips or I deas will help me alot. I will be starting a youtube channel to show you guys the process of the engine swap and keep you updated |
Hello Juantoids, welcome to this forum.
If I were in your shoes, I would tear the current motor down first to find out what's causing the knock and then decided to either rebuild or replace.
Welcome! |
[IMG]//scontent-ord.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/11030082_1430318640594744_8787272262307150996_n.jp g?oh=8557903061eb1387ad3418849d3a8d9f&oe=55B807BA[/IMG]
my BABY
Originally Posted by Rottieiller
(Post 700059)
Originally Posted by juantoids
(Post 697816)
To start of I've never done anything like this before. I've read a lot online on what I need as parts to do this swap but I was wondering if anyone has any tips or specific parts I need for this swap? I want this to be a simple and yet affordable swap. Is this swap possible to do with a budget under 2500? Any tips or I deas will help me alot. I will be starting a youtube channel to show you guys the process of the engine swap and keep you updated If the plan is to convert to a carb then you'll still need a stand alone computer to run the transmission. You may be able to adapt to an older trans, but that would cost more than getting the computer to run a newer style trans that bolts right up to a 5.3 LS. Of course the cheapest route is buying or building a SBC 350, and skipping all the swap of engine and trans. So if the budget is tight, I'd stay with a SBC, and keep it simple. |
