Where is reverse switch?
Hi all. I have a 1980 Z28, and the backup lamp won’t light up in reverse.
when I cycle through the floor shift, it comes on briefly before I get to reverse, then shuts off. So I am guessing that the switch is loose or out of alignment.
i took the center console out, but can’t find any electrical connection going to the PRNDL, other than the lamp.
Is there another switch somewhere?
I think the auto is in the column, might try adjusting the shift linkage a little and see if that changes it. manual is on the trans.
