wheel studs
ive got a 79 camaro. i bought a set of new rear wheels for it but my stock wheel studs are not long enough. i bought a set of new studs from jegs that were saposed to fit, they are the correct knurl size but they dont even go in half way. ive stripped out about 5 nuts now trying to pull them through. am i stupid for doing this? thanks for the help!!
Originally Posted by thatcamaro
(Post 514881)
Here's my method for installing them that works most of the time. I push the stud in from the back side; then I put some grease or heavy oil on the threads and also on a washer that will be against the hub or face of the axle. Then I put a good nut on the stud with the flat side towards the washer and grease on the flat side of the nut. Now turn the nut down and when it's snug tighten it until the stud pulls in. Don't reuse that nut for the next stud, as eventually you'll strip it out and it will be wasted. One use wont hurt it, but too many will. In the event the studs are so large that they wont pull in with this procedure, then I have resorted to drilling out the hole a size or two larger. It's pretty easy, and wont hurt a thing if you're careful to make sure the hole isn't lined up with anything behind that it will hit and damage when the bit goes through. A little enlarging will always allow them to seat, but too big and you're in trouble. |
thanks. i just didn't wanna hurt the hub or be waisting my time if i was doing it wrong.
I stripped some nuts out in the beginning too. The washers with grease make a big difference.
did you put them larger wheel studs in without taking the rear axles out of the rear end?
i need longer studs aswell |
Originally Posted by Jake Allen
(Post 605450)
I missed this thread the first time, but I would recommend to you the same thing I would have told the original poster. Generally, using different wheels shouldn't require longer studs. So make sure you are using the correct lug nuts for your wheels. Some aluminum wheels have a thick hub and use long shanked nuts that protrude into the holes of the wheel to catch the studs. If you have those types of wheels, do not use a standard taper style lug nut, even with longer studs. I wouldn't be surprised if using the wrong nuts was the issue the O.P. was having.
One other thing to consider if you're planning on racing NHRA events. The studs are required to extend past the surface of the wheel and through the lug nut. If it's strictly street, then a longer shank on the lugnut is a very reasonable, and easy fix.
