What is the correct master cylinder and combination valve
Can someone tell me and send pics of what a master cylinder and combination valve should look like. mine is being re installed and I want to make sure that Im putting the brake lines in the correct spot. If they are wrong then my car will not stop. Thanks for all of your help. Can you also tell me what happens if your cobination valve is opened. Thanks. Matt Vogt
