Transmission help
#21
Alright, I had to wait and sell my other clutch parts/flywheel before I could get the correct ones. Everything fits well, but now I have a new problem. It seems that my clutch adjustment rod is just not long enough. When I extent it all the way out, there is just a small amount of resistance when I push the clutch, at the VERY bottom. Is there an aftermarket that would work, or anybody hear about this happening?
Thanks,
Jon
Thanks,
Jon
#22
I think you got the wrong throwout bearing! There are two lengths for different pressure plates, a long and a short. If you have the low pressure plate and use the short bearing, you'll not have enough adjustment. Sounds like this may be your situation.
You either need the long bearing, or the taller pressure plate.
This is the long:
NAPA AUTO PARTS)
This is the long:
NAPA AUTO PARTS)
#23
This is the long:
NAPA AUTO PARTS)
This is the long:
NAPA AUTO PARTS)
#25
I also learned the hard way many years ago, using a long throwout bearing where it should have been a short. Clutch didn't grab 100% and got worse from there. But, the parts store sold me the wrong one and did exchange it. Do you know which style of pressure plate and which length bearing you have?
#26
#27
You should certainly know once it's apart. Although, can't you see enough if you peek into the shift fork hole on the bellhousing? When you compare, there is a noticeable difference between the two throwout bearings. This will help to show what you're looking for with respect to the bearing and pressure plate: Throwout Bearing and Pressure Plate
dsinclair999
02-21-2011 11:24 AM
