Transmission
Old Oct 26, 2008 | 08:27 PM
Saaampson74's Avatar
Default Transmission
I want to swap out my auto transmission from my 81 z28 but i dont know whats compatible with it all i know (which isnt much ) is that the the only the canadian v8 5.7 models had a manual trans what can work on my engine??
Old Nov 1, 2008 | 06:10 PM
kyphur's Avatar
Default RE: Transmission
Many different transmissions can go in but there's a lot of parts you'll need to correct for different lengths of the transmission.
If you tell us what your goal is and what you're wanting we can start pointing you in a more appropriate manner.
Old Nov 4, 2008 | 12:15 PM
feltont's Avatar
I have a 78 z28 with auto transmission. i need a new shifter assembly and a guy is trying to sell me a slapstick shifter for it, and tells me it will work with my current tranny. Is this true? or was there a seperate transmission for the slapstick option?
Old Nov 6, 2008 | 12:12 AM
1969 SS's Avatar
the "slapstick" shifter came stockin some of the Z-28's. it will work with any 3 speed tranny, so you'll be all set. when I bought my first second-gen, it was actually a couple of months before I even knew about my shifter being a "slapstick"
Old Dec 17, 2008 | 03:58 PM
tode5tool's Avatar
i just put a ratchet shifter from b&m on my 2gear powerglide then put it on my th350 using the same parts. so ya it should work.
Inked88
Jul 27, 2011 10:57 AM
dsinclair999
Feb 21, 2011 11:24 AM
randolphdelpriore
Jul 4, 2008 11:05 PM
DeputyDog
May 22, 2008 02:45 PM
camaro girl
Apr 8, 2007 04:58 PM
