tire sticking out too far!
Old 05-16-2010, 12:45 PM
brownstone101's Avatar
Originally Posted by jason7504
yeah either that or getting a smaller tire or just run them until i get a ticket lol
thats the way to go man!
  #32
Old 05-16-2010, 06:01 PM
jason7504's Avatar
ok well i measured my current wheels BS and its around 3.25-3.50" and i have around 2.5" before it hits the shock and 3" before it hits the leaf spring
  #33
Old 05-16-2010, 07:45 PM
So to play it safe, call your current b.s. 3.25 + 2.5 = 5.75". Shoot for a wheel with 5.5" b.s. then, to allow for a little sidewall sway clearance on the back side. That will tuck the tires in another 2-2.25" from where they are now. Will that put them in a good place?
  #34
Old 05-16-2010, 08:01 PM
jason7504's Avatar
if they were tucked in another 2-2.25", they would only stick out about 1/4" since they are sticking out 2.5" from the top to the fender but alot closer Cragar makes a 6" BS which would be too much but so close to 5.5" lol
  #35
Old 05-16-2010, 08:06 PM
A 6" backspace isn't a problem. Too much backspace can be easily dealt with by going to a spacer between the wheel and the drum. If the spacer is under 1" it will be fine, but I'd never run over a 1" spacer. Might need to change the studs on the axle out if the lug nuts don't get enough threads with a spacer.
  #36
Old 05-16-2010, 08:13 PM
jason7504's Avatar
well if a 5" backspace would bring the tire under the fender then i could always use a >1" spacer on the 6" wheel and it should be fine right?
  #37
Old 05-16-2010, 08:20 PM
Yes. That should do fine, but you will need to pull the studs and put in longer studs to add a 1" spacer. Pretty easy job. Just remove the brake drum, hit them with a hammer to drive them in, then push the new stud into the axle and tighten the lug nut to pull them in place.
  #38
Old 05-16-2010, 08:24 PM
jason7504's Avatar
so the studs just go into the axle housing when you hammer them in?
  #39
Cragar actually makes a 1" spacer kit that comes with longer lug nuts so you don't have to change the studs:
http://www.summitracing.com/parts/CRR-29200/
  #40
Old 05-16-2010, 08:26 PM
No, the studs don't go into the axle housing, they go inside the brake drum area.
Quick Reply: tire sticking out too far!
