Tilt Column
Old 03-31-2011 | 01:40 PM
gthmcty1's Avatar
Default Tilt Column
I have a non-tilt column car and would like to switch over to a tilt can someone tell me if a newer style Camaro (85-99) tilt will work? Or a will one from 75-81 fit?
Old 03-31-2011 | 03:30 PM
gfrench's Avatar
what year is your car?
Old 03-31-2011 | 04:18 PM
gthmcty1's Avatar
1974 sorry
Old 03-31-2011 | 07:33 PM
gfrench's Avatar
I believe the 75 to 81 will fit. I am not aware of any difference.
I would look close at any 79 or new because that is when the dash was changed.
I haven't noticed any difference from 74 to 78 as for the column and wiring.
Old 03-31-2011 | 09:45 PM
gthmcty1's Avatar
Thanks GFrench!!
Old 03-31-2011 | 10:29 PM
80ZJoe's Avatar
July 2010 ROTM
81 is different, i tried to put an 81 tilt in my 78 (non tilt) and the column wouldnt bolt to the intermediate shaft. i had to take the shaft also but it did however hook up to the steering gear box.
Old 04-01-2011 | 01:24 AM
Didn't the dimmer move to the blinker stalk in 80 too?
Old 04-01-2011 | 08:53 AM
gfrench's Avatar
I would guess several things moved in 79.
Old 04-03-2011 | 01:10 AM
Phatbudde's Avatar
Not sure about the direct bolt of the camaros. I just did mine (1971) and used a 1996 Corvette steering column, It did need some mods. but nothing drastic. Tools I needed were a die grinder (cutter), wire feed welder. The hardest part was modifing the steering shaft between the colunm and the steering box. I just came into access of a column out of a 1985, the nice thing about it is it has tilt and extension. I will try to take photos and cover the swap in detail if interested.
Old 04-03-2011 | 10:09 AM
freak2180's Avatar
if the Newer Column has the highbeam on the column its an easy fix.......just extend the wires from the floor to the switch on the column ( provided you want to and it works). I had to do this only in reverse on a 87 chevy PU when it was stolen and the Column was damaged. No matter what I tried I couldnt get it to work properly so I opted to go old school and put a foot swich in it.
Quick Reply: Tilt Column
