temp gauge
Old Jul 24, 2011 | 08:08 PM
Have the stock gauge recalibrated at Gaugemarks if its that important. Again double check if its for gauges or idiot lights.
Old Jul 24, 2011 | 09:29 PM
Does the gage go hot only when the wire is connected to sender, or does it do it all the time?
Old Jul 25, 2011 | 02:41 AM
It should be cold with no power. Its basically a thermistor. It changes resistance with heat. The gauge just shows the resistance. Pull the temp sender and if its reading cold. (on the stock gauge) use a lighter or some other heat source to see if you can peg the gauge. If you can I'd say its ok. Also it should be the green wire, just in case.
Old Jul 26, 2011 | 02:36 AM
rusty vango's Avatar
there are companys that rebuild gauges.and they do good work .do a internet search for them and good luck
Old Jul 26, 2011 | 11:39 AM
I have had internet chats with Daniel @ Gaugeworks. He is very nice. He quoted me $200 to blast mine repaint (any color) and reapply the decals. Then he was going to move the stock red line up to 6500 for me. Then set the odometer back to zero. Then swap the clock for in oil pressure gauge, it absolutely looks like it came from the factory.
‪gauge marks
Old Jul 5, 2022 | 08:38 PM
Z28-camaro's Avatar
Default Wrong temperature sending unit?
Hello everyone, I have a 1980 z28 with a 383 stroker that I built. Engine has thruroughly cleaned at the machine shop, coolant passages were clean. The radiator was replaced with an aluminum 3 core radiator with polimer tanks on the sides, water pump is a new stock replacement for sbc. Thermostat is a 160. I struggled to find the correct sending unit in parts stores, they all showed them with a newer connector on the top, but when I finally found one with the button style, It didn't quite match what I thought was the correct part number. Temp always read 220, and even climbed up to 230 on a cruise event in my town. Pulled over because I thought it would over heat. Out of curiosity, I installed a mechanical Guage, Temps read at a steady 160-170 and have never gone above 190 in traffic. Not sure what to trust. Any suggestions or information would be appreciated as the next big cruise event is this upcoming weekend. Thank you.
Old Jul 5, 2022 | 09:24 PM
Might want to start a new thread,this one is over 10 years old.
Old Jul 31, 2022 | 08:38 PM
fazeelnawaz761's Avatar
I am new in this forum. I have some questions about this forum. These questions are shown below:
https://camaroforums.com/forum/70-81...at-next-86479/
If anyone has information about my question. Please give me answer below. I am very confused about this.
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
Dana
Jun 16, 2011 11:20 PM
imcdowel
Mar 9, 2010 06:16 PM
josh95camaro
Oct 9, 2009 10:15 AM
57dv
Aug 20, 2006 05:14 PM
