sunroof gasket
Old 02-04-2013 | 10:41 PM
Renegade's Avatar
Default sunroof gasket
Hi I am new to the camaro forum and I was wondering if anybody knows where to get a new gasket for my pop up roof (sunroof) for my 1977 chevy camaro and if anybody can help that would be great
Old 02-04-2013 | 11:08 PM
BasicConcepts's Avatar
Technical User
Sunroofs were never a factory option on the second gens (I think only the fifth gens come factory with a sunroof) anyways your best bet would be to get in touch with a reputable shop that installs aftermarket sunroofs and see if they can order you something.
Old 02-05-2013 | 10:56 AM
If by chance you can carefully remove a piece of the gasket, then you can get a cross sectional view of it and compare it to what is available in newer products. The seals used in sunroofs are a injection molded dense foam, and there are companies that extrude this stuff for various applications. You can buy just about anything once you determine the shape. Some of the universal trunk weatherstripping might even work.
Most the sunroofs used hollow foam, so it compresses and seals easier. Take a look at O'Reillys, or Autozone, etc. as they both carry universal foam, once you know what you have with a cut from your's:
http://www.oreillyauto.com/site/c/se...atherstripping
Old 02-05-2013 | 11:59 AM
Renegade's Avatar
Ok thank you guys for your help
rj44130
06-23-2012 09:27 PM
MN_Camaro
05-16-2010 09:49 PM
libertyforall1776
10-10-2008 07:55 PM
camarproKid
08-03-2008 09:52 PM
MusicMan
05-20-2008 09:08 AM
