suggestions on removing broken header bolt
Old 02-22-2012 | 10:51 PM
Probably wont hold long, and it will warp the flange so later it might not seal with two bolts when you get it fixed. But if you need to drive it I guess it's a temp fix.
Old 02-22-2012 | 11:53 PM
mike6208's Avatar
Flange might already be warped, could be why it was leaking in the first place. Might have to wait and invest in headers and maybe heads if I can't drill out the bolt
Old 02-23-2012 | 12:04 AM
MN79Camaro's Avatar
i would spend a little money on a tap and try that dont skimp on quality, much cheaper then new heads just my two cents.
Old 02-23-2012 | 12:25 AM
mike6208's Avatar
What size tap will I need if I ever do get this bolt out
Old 02-23-2012 | 03:00 PM
rydeer's Avatar
Mike, relax you won't need to replace the head! You may have to pull it though. The bolt is a 3/8-16.that will require a 5/16" hole( or "F")Try to run the motor till hot and then work on the bolt. Wear gloves as you will burn yourself. AS a last resort go to an automotive machine shop,they will probably be able to remove it for you!!
Old 02-23-2012 | 04:02 PM
Worse case scenario is it might need to be drilled out and a heli coil installed, but I don't think the head needs replacing.
Old 02-24-2012 | 12:15 AM
PM me. Send me a self addressed, stamped envelope. I'll send you a couple 3mm carbide bits. I have tons of them. They will eat that easy out for lunch. They break VERY easy. Like if you drop just the bit on the floor it will shatter.
Old 02-24-2012 | 12:54 AM
You really don't need new heads, when all else fails you can take the head to a good machine shop, they will have the tools to get the stud out without costing a fortune Or if you feel ambitious, you could probably do it yourself with the head off. Get a full carbide drill, not a masonry drill, and drill the the stud out and tap the hole for a helicoil. The carbide drill gets very hot and will have to be kept cool by flowing water on it while drilling.
Old 02-25-2012 | 10:01 PM
mike6208's Avatar
after hours of drilling and help from all you great guys, i got the a helicoil in the hole. header is on but still leaks from the top of the middle manifold, cut the header braces to give me a better fit, picked this up from a guy to works on race cars.
video here also now that my bolts are on, how do i go about fixing the leak? thicker gasket? i dont think i can go any tighter on the bolts without breaking one again
or i can file down the header ports to make sure they are flat and run no gaskets and use a high temp sealer? seen around google guys using this approach.
  #20
Old 02-26-2012 | 04:43 AM
I have cut them before. I see no reason not to really.
Quick Reply: suggestions on removing broken header bolt
